ArSilicii BC 520 Lithium?
Lukas
Beitrag von Lukas »
Hello guys!
Do any of you use the Arsilicii BC 520 charger for a Lithium battery?
I saw that the manufacturer of this device confirms that it is compatible with Lithium, but SW1 and SW 2 need to be turned OFF.
If you use it, can anyone tell how it behaves?
Thks!
XGO-69G 21'
Re: ArSilicii BC 520 Lithium?
Beitrag von Vic »
Hello Lucas,
since I’m planning to replace my Pb-battery by lifepo4, I’m asking my self the same question. I decided stay with the BC-520 and also wondering wich jumper setting is the closest to the lithium. I suppose most of the LiFePo-Batteries require 14,6 V. According to the table ( see below) in the BC-520 manual the AGM-setting (14,5V) is the best for the lithium unless the both jumper-off-setting (AUS/AUS) was dedicated programmed for the lithium battery.
Yes, with 14,5 Voltage the batterie won’t get totally fully charged. But my Votronic booster has the right lithium setting and willcharge the battery till the end while driving. Also possible to connect from time to time a simple ( cheap) charger with 14,6 V to let the battery do the cell balancing. But this is what you gonna do every couple of weeks.
So, for my ( complete theoretical) opinion, you can use the BC-520 with AGM setting or you let them do the programming for lithium.
Many greetings
PS: please share your experience here if you got further with your plan
Lukas
Beitrag von Lukas »
Thank you for the answer!
At the moment I have installed 2 AGM batteries of 100 ah each, batteries that are also charged with the help of 2 pcs -300w voltaic panels from Victron and a 30A Victron MPPT.
In the future I want to replace the current batteries with 2 lithium batteries of 100ah each. I will try to use with the current Arsilicii BC 520 ... I hope everything will be ok!.
Dear XGO'ers,
I am also responsible for what I do on the motorhome. If I don't know what I'm doing, it's negligent. Then the insurance will expire in the event of an accident or fire.
Zuletzt geändert von beluga am 07.01.2024, 21:32, insgesamt 1-mal geändert.
Hi Uli,
ja du magst recht haben das dies ein deutschsprachiges Forum ist aber ich persönlich habe da jetzt kein Problem mit der Frage auf englisch.
Wenn jemand auf englisch fragt und jemand auf englisch hilft, ist doch alles gut.
Ich hätte auch noch geantwortet, dann auch auf englisch, aber Vic war halt schneller.
Ich dachte wir versuchen zu helfen, egal in welcher Sprache.
Aber vielleicht schaue ich auch zu viele englische Sachen und spreche zu viel englisch an der Arbeit, als das mich das nicht stört.
Wo habe ich nicht mitgekriegt das er ein Norweger ist?
Aber wie gesagt: Ja, Forensprache ist vorzugsweise deutsch, aber was anderes verboten habe ich auch nicht, oder?
Ich freu mich über internationales Publikum und auch über Fernsehbeiträge. Ich freu mich überhaupt ganz gerne.
